Delete Codes in Unlinked
Does anyone know how to delete codes in Unlinked?
If you have your own unlinked store, you just log into your account and click the delete
I figured it out. Thanks anyway.
Good day @Peteywhwat1 . Perhaps you would be so kind as to tell everyone how you accomplished this. I never use Unlinked, but as you had the issue initially there may be others who are also wondering how to do this. Thanks for sharing.
I held down the store in Unlinked that I wanted to delete until it gives you the choice to delete. Press the link and you’re good to go. (after you download that specific app)
