I downloaded Filmplus and Cinema with the downloader codes and unlinked and the scan designates them as suspicious. Has anyone else had this problem? I get the same result on my 4K firestick and the ONN.
Ya especially if they’re moded apps. There are several false positives.
I do believe cinemahd even from the main website will produce false positives, you can ignore it unless you got it somewhere els.
Id advice against cinemahd. These programs will almost always flag falsely for what they can do.
Thanks, loaded new version of Defsquid. The ONN version had no problem in the scan, the FS version still had problems with Cinema.
Thanks, see my post.
2 choices… use something els or ignore the flags. Cinemahd will always flag or at least 80 percent of the time.
