I’ve been using an unverified IPTV provider for the last three years or so. I’m generally very happy with the service with one exception. Every night around 7PM (Central) the stations start to suddenly go black, flash on and off for a few seconds, return to the program either before or after where you left off, run OK for a few minutes and then repeat the cycle. This goes on for 30-45 minutes and then clears up and is good the rest of the evening. Just wondering if anyone else has experienced something similar with their provider. Thinking it might be a daily server reset or something like that.
My guess would be your provider doing maintenance considering it’s daily. I’d reach out to them and ask.
What is 7PM for you might be midnight or later for your service provider. @Sledgehammer is probably correct.
