Daddylive won’t install
Following Troy’s latest newsletter I tried to install Daddylive on my KM7 box. I got a message saying it failed to install.
I am using the latest version of KODI. I used the Crew repo I had installed some time ago but the version 0.3.6 is the same as in Troy’s tutorial.The Daddylive version I was trying to install is 4.18 which is later than that shown in the tutorial 4.04.
I could install something else from this repo as a test.
Any suggestions as to what might be the cause of this problem would be greatly apppreciated. Thanks.
The latest version i have is 4.19. It comes installed with the build I use.
What build do you use ?
Diggz Xenon Plus
Just tested, both live tv and sports areas are working with Daddy Live
https://tinyurl.com/diggz123
Its part of an AIO (All In One) build now. After downloading you select a few movie/tv addons, active your debrid and Trakt and then select a Skin. I prefer the Xenon Plus (first option). Take your time to let the build load. It works great on my onn, onn pro and Nvidia shield.
Any questions or problems there are many links here to help.
The KODI build is 21.0.0
I don’t have abui,d - I just use KODI as it comes on installation. I don’t have a problem istalling other addons from tbe Crew repo or others
I understand. @scooterboy952 was asking what build i use. DaddyLive is working in that build. Not sure why you are having problems.
Not to confuse anyone else but the Kodi version is 21.1 not the build.
Here’s the latest version, it’s 4.19, the same as JPM69’s.
https://github.com/thecrewwh/zips/raw/refs/heads/master/matrix/_zip/plugin.video.daddylive/plugin.video.daddylive-4.19.zip
Remove Kodi and reinstall it! I was having issues with Daddy Live and live tv so I removed Kodi and reinstalled it with the Diggz build and it’s working like a champ! :mechanical_arm:
Just this evening I managed to get Daddylive installed and working in the standard KODI build. I updated the Crew Repo and that had version 4.19 of DL which installed whereas the previous version 4.18 did not
welcome
