Holy smokes, this one has got me!! I installed firesticks for three neighbors and downloaded Kodi along with The Crew. I also enabled Daddylive. I cannot get Daddylive to work on one of the installs - keep getting the error message to check the log. I tried uninstalling and reinstalling but no luck. It’s nuts!! Any ideas would be greatly appreciated.
are all sticks the same generation
I believe all are Firestick 4K. What are your thoughts?
if the sticks are all the same gen then it seems a file might be corrupted ie either in kodi or daddylive check what version you have of kodi but i would delete and reinstall both an try different source for daddylive
What did the error message in the Kodi log say? Were you unable to access it?
I noticed upon downloading Daddylive I see 2 links, one works well the other reacts as you describe. For sports, Mad Titan is the best because I very seldom have issues with buffering. The best link there is streameast 2. Also, I switched from Surfshark VPN to Nord which gives me faster speeds.
Don’t know answer but I lost daddy live add on on all three of my firestick 4K on KODI/troypoint and on Diggz and elementum
Correction after downloading new AIO Diggz burst (under tv guide caption )on home screen it appears and works …did not look for it on tv guide caption just looked on video add ons…….still lost Daddy live on old builds though even a search for add on shows nil…
You might want to cut and paste this to the other thread you were just on. It will probably get moved there anyway.
Its still a DL issue even though a slightly different topic.
If you know how to install a Kodi addon from zip file, here’s the newest version of daddylive 4.18.
Short url:
http://aftv.news/812692
OR
Code for Downloader:
812692
I agree. I started with DaddyLive, but had streaming issues and have used MAD TITAN SPORTS for years.
Daddy live works fine for me using an android box
NO vpn and i am in Thailand
When I started losing builds I realized that my stick was not up to it. I subsequently got 4K max and that solved those issues.
