Picked MX for video. First video worked fine, selected next video and get this message:
MX Player Error: Last playback was ended with an error. Can’t get solved.
Thank you in advance for help solving this!
I like MX player best of all the options available. It’s been very reliable for me. First thought is do you have the most recent version available via Troy’s rapid app installer? And even if you do, try uninstalling and then reinstalling. Always a good 1st step if you haven’t already done so.
Is there a way to use the VLC player? If you have it installed, does it give you that option? Always had good luck with VLC.
When I have a problem with a player like MX, I just switch to another one which usually solves the problem. Try VLC or Yes player etc.
