Custom launcher for Stock Android 11 TV box?
Any recommendations?
I’m having a hard time distinguishing between what would work with stock OS’s vs TV OS’s when trying to Google the information.
Wolf works fine on stock…
I guess I’d have to install a launch manager to use Wolf Launcher.
yep. Only box I ever used that didnt require a launcher manager was ugoos. Nothing is locked by them.
I don’t use a launch manager on the z11 pro max either because in the settings you can set whatever app you want to launch on boot :wink: so everytime I power on it opens on wolf.
I just installed it.
It works very well. Nice thing is that it’s easy to toggle between Wolf and the stock launcher because both icons are present on both launchers.
I the launcher Manager will display all your launchers and then you can decide which one you want, or you can select “Always” and it will automatically go to that one. To Disable Launcher is one click and then click your “Home” button and it will take you back to your stock.
You might give TVLauncher 3 a try off the google Playstore. Very easy to set up and use, including your downloaded stationary and live wallpaper apps.
