Custom 8GB ram 128GB rom Tv box Android 13 Media Player TX10 pro Smart TVBox Quad Core 5G WIFI 4K Set-Top Box android tv box
100% Agree. I had flawless performance with my 6 year old T95Z Plus cheap China boxes. Good speeds on wifi and 4K so thought I might get the same for a $11 box. No big deal.
I haven’t got mine yet but it is for play if anything. I’m not into hardcore video/audio stuff so for me it might be OK. It will be interesting
Hi Tx10 pro i just got the box. Can someone tell what av adapter goes with this box? Unsure what av adator to use. I looked for one for this box nothing came up.
I have a adaptor from other Android box. Unsure if i can use it.
I haven’t found any videos that are english speaking to show the step by step process of settling this box up. Is it easy to set up?
I would appreciate the help. Still learning.
Thank you
I haven’t gotten mine yet but i remember selecting a US adapter. Your didnt come with one?
If you’re talking about power adapter they are the same. For tv hookup it should have came with hdmi cable and power adapter. Just regular android boxes power are the same.Output on your adapter should read dc 5v 2a .
I specified US adapter when I ordered. Came with everything I needed except batteries for remote
Hi MarkxG, I ordered mine from Walmart. I didn’t get adpater. I have adapter from previous android box. Unsure if this will work with this box. Is there certain adapters go with certain boxes?
I know onn boxes have there own adapters because when i searched on walmart website i saw onn adapter.
Hi josh31, i have the power adapter. In back of box it say av. Which iscav port. The power and hdmi came with box. I have a adapter from previous android box. Unsure if each Android box has its own.
Did your device come with any power specs? If so, see if it matches the power supply you have.
I checked my walmart app and didn’t find the device on there but maybe its not available near me.
If you can’t find any specs then ask walmart.
I know longer have the info from the adapter. So there is no way to compare what i have and what they are asking for
There isnt really small print on the part that plugs into the wall? Use a camera and zoom if needed.
Also, what device is it from? Look at the specs for that and see if it matches.
Very confused? This is a cheap Chinese box that is ordered from Alibaba not Walmart? You can’t get this box at Walmart. I was only saying that during the ordering process it prompted me for an adapter in 3-4 countries. Being in the US I chose the US adapter
Sorry for not understanding your question
this box is for sale on Walmart for 39.00 . online
TX10 pro H616 dual wifi 6k Smart Tv Box 8GB 128GB Android 13.0 voice control remote Set Top Box
(No ratings yet)
Count:8GB+128GB
selected, 8GB+128GB, $39.098GB+128GB$39.09
Actual Color:US
selected, USUS
I found it. I had a space between the X and the 1.
It says it comes with the power adapter so not sure why there is an issue.
On a side note… for $10 more you can ge the Onn 4k Pro and probably have a better device. Or at least one that’s been reviewed and recommended.
Most of us bought it (tx10 pro) because it was super cheap ($11) with high specs and took a chance.
Wow you are spot on! I wonder if I can take the $11 Box from Alibaba walk into my local Walmart saying it’s defective and get $39 store credit! :roll_eyes: :rofl:
I purchased from Walmart because it came quicker and if there was a issue. I can return it. Plus the box is 8gb ram and my previous box was 4gb ram. Onn box is only 3gb ram.
I have the power adapter to plug into box and wall. They didn’t provide a av cable. I have one my previous android box.
If the Formuler had the z12 out. I just would purchased that.
So for now I use this
My bad i thought you needed the power adapter. I must have misread.
Is the hdmi cable not providing you with audio and video?
Hello all! I received my tx10 a few days ago and waited to post just to see how it ran for a few days. Not impressed at all. Very buggy and slow at times, also the ethernet and wifi connection is horrible. I just stream and do not record and would not recommend this box at all. The Onn pro is alot more reliable and faster for a few bucks more. Maybe I got a bad box, not sure but will not waste anymore time with hoping it gets better.
This is in line with my posts above especially on the wifi. I get close to 400 Mbps down consistently on wifi on all other devices. Couldn’t get more than 60 on this one. Have you tried to play anything in 4K? I couldn’t and nobody has verified this box can play 4K sources. Not a big deal as I’m only out $11
I would be careful with these cheap Chinese boxes. Might end up with a bunch of Android boxes blowing up in the USA!
