Cudy AX3000, AKA WR3000
Similar to TXRon and his GL router, I was set to give a glowing report with this Cudy router.
Great UI, worked great with ProtonVPN Wireguard and OpenVPN. Great coverage of our house, etc, etc.
However, it crapped out after two and a half weeks. It stopped communicating with the modem and I couldn’t log into the router until I did the factory reset, which I reset it three times. But no matter what, the router wouldn’t connect to the modem. I had put our elderly TP-Link router back to work.
Fortunately, Amazon makes returns easy.
I can’t say much about the cudy routers other than they have become Amazons budget choice.
