CrewNique & Seren
If I install CrewNique will it affect Seren which is currently installed?
If you already have the crew wizard installed you can go into the settings and go to “install settings” then make sure everything you want to keep is “on” now when you are given the choice between “fresh” or “standard” install, choose standard. This usually works for me good luck @mscardigno
Thanks, PapaS, I’LL GIVE IT A TRY.
Chances are you already installed it, but if not….
Be aware, missing steps in the written version of the how to, watch the video, it has all the steps.
I brought it to his attention, IDK if he fixed it.
