I have the crewnique build installed on my Fire TV Cube and everything works perfectly except movie/tv show trailers. When I select any movie and go to information and then trailer, all I get is the loading circle for less than a second and then nothing happens. I installed the IMDb trailers add-on hoping it would fix this but that had no impact at all. Is it possible to get trailers to work? If so, what do I need to do to make it happen?
I am not sure, but I believe most trailers are coming from Youtube. So, I would check for a Youtube addon. Don’t know if that will solve your issue, but it is worth a try.
If I added the YouTube add-on would I need to do anything in crew to link them?
