I istalled the Crew repo but it’s not opening . When I try to open it I get a message saying " Can not connect to repository . Anybody else having this problem ?
You probably misspelled the repo. Make sure its spelt correctly.
The repo did unzip an loaded but when I go to insall by repository an try to open it I keep getting the message " Can not conect repository " Is the repo down ?
It could be your internet or it could be the server that the source is on. Sometimes an addon will install first try and sometimes it will install on the 6th try. Good luck ![]()
My internet is fine . I reinstalled it twice . Will keep trying .
I’ve just tried it and no problems,
I tried it again yesterday an it installed . Don’t no what the problem was but got it now .
