Anyone else having problems with the Crew Add on this week? I went to watch one of my favorites and could not get any links, even though other apps had them.
The crew is working, please use our search as this is a big common thing.
Are you trying to use crew without a real debrid service? The crew fee will not get you shows and movies they come and go
For weeks now I have not been able to use The Crew or Fen. I get plenty of RD links but whether it is a movie or tv show I get the message: no stream available. I thought I fixed it this morning by deleting Kodi 20.4 and installing 20.5. I was able to get a movie, but now 6 hours later it is back to the same old same old. Live Daddy works fine. Any help woul be much appreciated.
P.S I seared and I read nothing worked.
I just tested The Crew. Its working. Make sure your Debrid account is up to date and authorized for the addon.
The Fen apparently is or has shut down. Look elsewhere.
This information is definitely available using the Search option.
FEN should continue to work now and going forward but without regular updates, it will eventually fail to work acceptably.
I haven’t tried the Crew but Fen is working fine on my end.
Plenty of FEN forks out there that are still actively being maintained - nothing new here.
While FEN, as said, will eventually become not viable for use, just migrate over to one of the other skinned variants that are still getting updates from it’s dev.
As for Crew, ensure your RD premium sub is still active and not expired.
switch to Scrubs 2 for movies, ( old an New)
BUT seems for new tv shows it doesn’t find streams
Do NOT need RD
I used a posted video to install Kodi and Crew on 2 android boxes. the first install was on a pretty old box, and went very well. The second was on a ONN 4K Pro. The Kodi/Crew install worked, but for some reason I was unable to authorize my Trakt account on Crew. I was able to authorize it on another add-on(Umbrella), so I’m guessing it isn’t the box. I would appreciate any suggestions.
Thank you Jayhawks569 for a very helpful video.
Crew is pretty much dead as has been mentioned. The Dev has abandoned it.
I asked on The Crew Telegram channel and they said, NONSENSE! It lives on and is constantly being worked on.
@mike189 If you’re looking for a new add on, Troy did a post on the add on “GEARS”. I added it and it’s pretty nifty. Quick, colorful and I really like it.
Good to know I thought it was dead. Used it for years but now prefer Umbrella and Fenlight AM. For me they are much faster and I think that is due to the cocoscrapers
I tried The Crew several times and think it’s horribly slow and clunky. I love FenLight, POV and Gears (since Troy’s post on it).
GEARS/zorro/chainsgenocide/zap/hawk are based on an older Dradis version.
Dradis has been updated several times since and will continue to get most support.
I’m not sure what troys or robot ronnies motivation is for this.
peace pooks. ![]()
