Has anyone tried this? I was wondering what add ons are in the build. Thanks
James
I am trying to do the Crewnique build per today’s Troypoint email. I uninstalled and reinstalled Kodi 19.4 and followed all the instructions in the tutorial. When I get to the Click Fresh Install screen I don’t have that choice. In fact my screen doesn’t have most of what is on the screen in the tutorial! I have a long list of items. Help!
Thanks, Diane
I also set up crew nique on Kodi 19.3 all works well except I can not get sports to show on the main navigation panel. BTW I tried to download the 19.4 on Troy point apk but all I get is a message that it is downloading until it times out. Any help on either of the above issues would be much appreciated.
All rai reports must go into the topic i created for it, i will double check all rapid app stuff tonight.
I also attempted this download. Everything was great until I got to the “fresh install” part. This does not even appear during the process. I admit that I’m no Kodi expert, but I can follow instructions. This is frustrating. Anyone have any ideas???
A fresh install is deleting kodi entirely and starting over. Reinstall kodi and addons.
I deleted Kodi and started over by reinstalling it… same issue. Crew nique is a bust, unless it just doesn’t play nice with Nvidia shield or something…
next time instead of deleting kodi just go in to settings and clear all data, then you still have kodi just no build.
Same here. I’m curious what addons are included other than the crew.
Go into settings and force close the app then open it and try again. Good luck
What @TXRon said ![]()
