I have the same problem I am not sure why either
I found it It was 19.3 BMC and I put diggz1.me/giggzrepo on it and it came right on it is great I have other KODI on other firesticks but 21.1 does not work as well as the 19.3 I wish some one would give me the source for 21.1 and other 19 ones now because for some reason they keep changing everything
I would like to have 19,5 but what is the source when I use diggz1.me/diggzrepo that does not work any more could someone tell me a new source
That looks right but you need https:// first.
Edit
You cant install diggz on anything other that kodi 21.
Yeah, Troy has the Kodi versions and forks down to 18.9 in his Toolbox, but I still donât understand why you would want to be back there. Add-ons get updated constantly to work the best with the stable version of Kodi. Yes, some lag a little, but eventually the developer better catch up or they will be the next Kodi add-on in the garbage pile. I hear things like, 19.5 worked the best for me 2 years ago, but the same add-ons have been updated for compatibility-sake and likely wonât work as flawlessly now on that same version. To each his/her own, I guess, I just donât understand why we use the current Kodi Stable as the scapegoat so often in here.
I agree. Not sure what the fascination is with older kodis. But as you said⌠To each their own.
Most people hate change. They get fixated on an Addon and will go down the rabbit hole trying to get it to work. Itâs always best to use Addons that work with the latest stable version of KODI. Not being open to change does not often work with this hobby because Shi$ breaks all the time
Real Debrid
After a long hiatus from Kodi I installed version 21 and The crew. All is working fine accept I donât get the option to resume on any movies or tv shows. Even if i pause it, leave Kodi and then go back in, It will always start from the beginning. What am i missing? Is there something in the setup that I didnât do?
Replied to your question in the other post
