Yes Umbrella works with RD and Premiumize. Possibly All Debrid too but i never used them.
Some addons didn’t adjust to the new RD set up.
Yes as @JPM69 said above. Real Debrid working great on Umbrella. Try Reauthorizing in The Crew and see if that helps. Also make sure you still have days left on your RD sub
I recently added days to my acct. and yet, it still doesn’t work. Even tried deleting Crew and reinstalling a new version, (re)authorized a new code and still only get “no stream available” and this is after the “paid” populates with tons of 4K, 1080, etc… I must be doing something wrong, but can’t figure out the obvious.
I just tested The Crew for you and only received links from Premiumize.
Haven’t used The Crew in several months as Umbrella is so fast and my new go to but just tested a few shows on The Crew with RD and nothing played. I suggest installing Umbrella with Coco scrapers. Do a search here for detailed instructions. It’s working flawlessly
Using Crew, Real Debrid finds 56 links, choose any of them lately
and it says NO STREAM AVAILABLE?
Make sure your Real Debrid account is up to date. I havent used The Crew in a while. I think they still allow RD. Some developers didnt fix their addons from RD problem a few months ago.
I reatuhorized Real-Debrid and the same thing is going on.
It will find 56 links and when I choose one to five, I’m still getting
No Stream Available. Please don’t close this thinking you have
provided me the solution. Thank You
It wasnt closed but moved to a thread about the crew not working.
Check your account status with RD. Your subscription may have expired. That is different than reauthorizing on the addon.
As JPM69 suggest, checking your RD status is the first thing to check. It is typical to expire since they don’t notify prior to the expiration of the account.
Many hard-core Crew fans have moved away from the Crew due to various issues. The new hot addon is Umbrella. That might be worth a look.
Well, I’m saddened to say, that Real-Debrid expired.
You have been right all along even though it allowed me to get it authorized on a new umbrella install.
I would of sworn on a stack of bibles that I had just renewed that
not that long ago. I installed Umbrella, cleared the cache on my Firetv stick and installed RD on Umbrella just fine, it was expired.
You arent the first and you wont be the last… lol
I made the same mistake once as well.
Make sure you mark your calender this time…![]()
Umbrella with Premiumize for the Win !!!
Vewrsion 2.0.6/module 2.1.0a (running for a long time now) both have perfectly working searches in movies and TV-shows.
ResolveURL in Kodi on Raspberry Pi’s newest operating system -Trixie, for some unknown reason does not work. The Crew, Homelander and other addons that require ResolveURL to work are only providing the message “no streams available” Hope they fix this soon.
I’m getting that problem with the crew also.
I have a fs 4k Max and a firecube. I have installed the Crew on Kodi 21.3 recently on both but I cannot get any content. No matter what I choose, I get No Stream Available no matter what I choose or search for. Scrubs is working fine, though.
Hey there, are you using a Debrid Service? The Crew doesn’t really work much anymore without a debrid provider integrated.
No I am not yet. I do not even get any links.
