CREW IPTV add EPG
Very new to Firestick and Kodi. Simply put I followed Troy Point and the setup instructions were amazing. I got my libraries set up. All that remains is the Simple Client Live Tv. Based on TPs THE CREW…I only want to use the IPTV Live Channels (USTVGO) and add them all. Anyone know how to do that? Help is greatly appreciated.
@Fragernockle
Hi welcome to the platform
If you installed The Crew add-ons successfully
Open The Crew> IPTV> Then open any of the links available then on the channel you proffered.
(USTVGO) will be the third link to the bottom.
Note: Each Live Channels link contains different channels, and is very important to use VPN. If you don’t have any yet consider TP discount.
VPN Discount
If you mean PVR IPTV Simple Client, its in the Kodi Add-on repository. If you have a playlist URL for USTVGO, you should be able to use this guide to set up.
