Do I need to delete Crew before installing Daddy Live?
I really didn’t want to do that as I’ve saved 8 or 9 searches
that I use.
Daddy live is in the crew repository so it’s fine
When I went to install the Daddylive Repository, it shows the 3.37 version of Crew and not the 4.3 version of Daddylive.
You won’t be loading the crew all you will load is daddylive go to crew repo then video and download daddylive if you have crew I stalled it’s already in the. Repo under video
Also if it’s not in that version of crew you can just download the new one apps you have will still be there
I’m confused, I added Video of daddlyllive. It shows up in File Manager but when I click on install repository, it only shows Crew 0.3.7 and one that says "Kodi add on repository 3.4.0 When I choose the last one I get list of repositories but none say crew or daddylive.
Load crew repo Troy has instructions on here then load daddylive
@Franksr, they are TWO SEPERATE THINGS. Look at it like the repository is a 2 slot toaster. Do you want one slice? (the Crew) YES! You already cooked that one and are eating it now. You want another slice? (DaddyLive) SURE! Dont mess with the Crew, dont worry about that slice anymore. Add DaddyLive (the new slice) and when it is installed, POOF…butter that one and gobble it up too. You now have TWO things (addons) installed and can view which ever one you like, when you like. (provided DaddyLive is working at the time, which in my case it sometimes does not. It’s free and whoever manages it just does it for fun so dont expect high reliablity for it…but it’s good to nibble on when you can!)
I have Daddy Live listed now in my Add-ons, however, there is only two listings.
Live Sports and Live TV in which none of the channels listed in those folders play?
Thanks for your help. I do appreciate it.
as previously stated …“dont expect high reliablity for it”…
they both play
Don’t expect any type of reliability on Live TV in any of the KODI Addons. Yeah sometimes it will work great for weeks then all of a sudden gone. Best to look into getting a paid IPTV service. Lots of posts here if you search
It is in the Crew repo!
