Crew Add on not working ---- please help
Friends I’m a newbie and followed the instructions to install and the crew add on was working fine for several months. However now whenever I choose any movie link even RD ones, it says “no stream available” Could someone kindly help me fix this issue please. Thanks in advance for your assistance.
Hi @Vphilip, Welcome to this great forum. Just tried the crew and it’s working fine here. You could try going into “tools” and clearing the cache, also clear the kodi app cache on your device. You can check to make sure the repository is updated, your crew addon should be on Version 1.1.6b Good luck, hope this is of some help. Remember with Troypoint tutorials it’s pretty easy to re-install if you run out of options.
I am having same problem on all my devices, firestick and Onn. Have tried everything and no luck.
Mine works. Was recently updated and now at version 1.1.6q
Sorry typo 1.1.6b. Not q
Thanks very much…that worked!!:+1:t4::pray:t5:
