Crew Add on and all the problems
Anyone, ANYONE, get me up to speed on the Crew Add on? I search anything, gives me the two dots. I click on anything, the two dots. Everything, the next screen is the two dots. Anyone have any updates? Or an equal alternative where I can still use my real Debrid account?
Should’ve probably said I’m running 20.4. This started when I still had 19, which I ran for a while. I figured upgrade to see if it worked, does not. Is this the end of the Crew?
Give fen a go. Theres a turorial somewhere on the site.
From the zip file install the repository, then the crew is in there.
https://team-crew.github.io
Personally I don’t recommend it.
So many people having problems with the Crew I do not understand it??? It has been working flawlessly for months.
What version of Kodi are you running? I ran into some issues trying to run The Crew with Kodi v.19. When I updated to Kodi v.20.2 and reinstalled The Crew, it’s all been working flawlessly. That said, The Crew is my “backup” app. I use Seren (not Serenity, which is “Seren Light” as fas as I’m concerned) for movies and TV shows, and for live games, it’s Mad Titan Sports for me.
And, Seren works with RD. It’s not applicable to Mad Titan, since I’m watching live events.
I don’t know how Crew is popular, but I found a way to use it effectively. Crew has about a dozen Add-Ons in it’s own repository. Click on install from repositories and choose Crew. When you open the Crew Repo and choose Video Add-Ons, it opens a list of Ad-ons inside. I have downloaded them and they are fine. I usually use Moria, Homelander and Chain’s Genocide. Real debrid works well in all of them. As a rule I usually install the RD in each Add-On through their Tools or Settings links. Hope it works for you too.
Thanks all. I’m running 20.2. None of the crew repo add ons work. Deleted. Reinstalled both crew and kodi. Seren not working either. Gonna give a premium iptv a go and see how that works out. So far so good.
The Crew Addon is working great. I am not sure what you are doing wrong with your install. I use it in a Build
Movies on the Crew is working fine for me but when I go to TV shows I get two dots and obviously can’t access the shows. Is there a solution?
