What do you guys think about this cracked copy?
Support the developer. It is not much money.
First there is a free version, but if you need the additional functions then I agree with @hotwheels, it’s less than 8 dollars (US). Support the guy.
A lot of people justify watching movies and shows free pointing to the greed of the streaming services, that is at least a simi-valid argument.
But a cracked version of Projectivy? You do you, I certainly hope you can continue to feed your family if $8.00 is beyond your means.
i’ll try anything that’s free? my family is none of your concern?
If you don’t know who cracked the app, you don’t know what code has been added.
Exactly but some are happy to use apps with malicious code for some reason because they can access your device and use your ip address for what you don’t actually know.
PL is definitely worth the cost for the extra features I use, but the free version that the dev already offers is also great value imo.
The family line was sarcasm, which doesn’t always translate well in text message, an age old problem on the Internet.
I’ve used this on all my devices for a while now, didn’t know there was a paid option.
What does it do extra?
All i saw was porn, didn’t see an option to download
@ Denbo
i was just there? these are the download links posted at the bottom of the page
This app has no advertisements
More Info:
https://play.google.com/store/apps/details?id=com.spocky.projengmenu
Download Instructions:
https://mega4upload.net/luriwptxm63k
Mirrors:
https://devuploads.com/3pe7lspurvka
https://modsfire.com/VPbbn0c2fpMe9G2
https://uploady.io/nfg86t4q706r
I am currently using the free version but I’m curious what the premium version does differently? The only thing I have used it for is to clear the homepage of my new ONN box.
I use custom live wallpaper and have changed all icons cards with transparent ones.
There are other features but I haven’t used any of them yet.
I like customisation features of the paid version as I do with Kodi skins and widgets but those are free.
question? I paid for the premier upgrade and put on the new onn4k pro. do you have to pay 8 dollars for each box or can I put on my other devices. And if so how!!
I am curious about this also. log in with the same email on another box. go to playstore and down load again.. or do you have to upgrade within the app? let me know the results.. just curious myself
I have paid IPTV service , wondering if I can install this launcher of my firestrick4k max without causing issues
I am all about trying something for free. Like just to check out is it worth buying? Do i need the options the free version doesn’t have? When i installed hacked version on an ONN 4k Plus box.. which comes with android 14.. it gave me the same hassle that troy talked about in the original review of the ONN plus.. when i try to turn on accesibilty options for projectivity launcher.. it switches right back to off. when i download the trial from play store.. i do not have that issue.. so I didn’t get to test all the features of the pro.. the free one works fine.
BUT.. if i was able to install it on more than one device i after i bought the paid version.. i would definitely do it..
I would like to pay for the Premium version to use on my FireTV devices, but despite having a google account and android phones, it says I have no devices that Projectivy can be installed on. Is there a way around the restrictions?
Troy’s guide,
Thanks for the response Mike.
I’m trying to get the Premium version - I’ve installed the available on TROYPOINT.
