Could not connect to repository
Hello all.
I’m trying to put misfitmods back on my firestick 4k max. Everything goes great till I get to repository. Then I get the above message. Very disheartening. If you know what I mean.
Anxiously awaiting in Colorada
J
http://misfitmods.com/mmwiz/repo/
Type in the address correctly all lower case.
Thanks for the response but with Kodi 20 it says after you click on install from repository
Misfit mods: Repository (then underneath it says)
Could not connect to repository.
OK
Have done a fresh kodi install several times. Same error. Anyone having the same issue. Does it matter if I moved Kodi to an SD Card under the Fire TV Applications
Never did before. Turned off SurfShark. The repository will not connect/load. Never has happened for years. All ears for suggestions.
@Durango4711
I don’t think that misfit mods is compatible yet with Kodi 20. I may be wrong though.
Based on everything I have read it only works with the previous version of Kodi ( 19 / Matrix ).
Thank you. I will give that a shot.
