Compatible micro sd card for 2nd gen fire tv
Hello Troypoint members! I was looking around and couldn’t find information on which micro sd cards are compatible with a 2nd gen fire tv box. I appreciate any help you can give me. Thanks!
@jeff0422
To be honest, almost any sd card should work.
But everyone I talk to uses SanDisk so start from there.
Agreed Sandisk is a good brand, just be careful of counterfeits, read customer comments if you’re buying online or save the hassle and buy in-person from a reputable vendor/store.
Be careful with the size as well, I believe it maxes out at 128gb. And it needs to be MicroSD format.
Capp
P.S. Your other option would be to get a portable USB SSD (solid state drive). Biggest advantage is speed. I bought a 120gb SSD for less than $50 on sale (Amazon) and I’ll never go back.
