Using Troypoint video, I set up Surfshark/Wireguard on my new X10 router. VPN speed has gone from about 10-15% of IP capacity to about 75%. The connection passes the leak test, but when I try to login to Surfshark website I get a black screen with red triangle warning > "Your connection is not safe?
Has anyone had a simular issue with this router?
strange, just go HERE to verify your covered.
You should NOT see your public ip in the results, so make sure you know it before testing.
TXRon,
I had previously used dnsleaktest.com. to check vpn ip address and see ip address 200 miles away. Thanks for asking?
Talk about strange, Brave Browser will not open my.surfshark.com account with Surfshark VPN.
Regards, Stiz
I the same situation, but with opposite results! My speed with “no-vpn” is 600ish, and with the vpn on, down to 100ish bpm (varies a little depending where I’m am connected, NY, GA,etc.)
So far, Surfshark Support has been of no help, except to recommend buying a new router.
Thanks…
