I often get this message when I try to stream a movie on Seren. It says something about downloading Vid-Codecs/Read text which basically means I cannot stream the movie or program without it. It’s frustrating because I don’t know what that means and I don’t know how to integrate it on Seren to make it work. Would someone explain what that means and if possible how to find it and then integrate it with Seren.
Please use search as this subject comes up almost daily. After searching, and reading what you find, you will have your answer.
Welcome to our community, as a newer user I would highly recommend looking around the site and guides, the search function is useful for finding finding info, this is a common problem.
It happens when new movies and shows coming out still in theaters or not available to stream.
I do hope you enjoy our insider. This will be closed.
