On Superman build when I go to install fm repository it say the cman wizard is unable to connect
Phew! I am not the only one then. I did notice at the end of the number after cman repository it ends with 9 not 8 in the set up picture
Exact same issue here. I keep getting a “Could not connect to repository.” error box when trying to install the cMan repository. Oh well. Back to the Green Monster build which I really like.
Having The Same Problem Here…
Did My Frist Box With No Issues Then A Few Days Later I Tried To Set Ip My 2nd Box And It Is Saying The Same Message…Can Not Connect
Same here since Thursday. Yeh tried to install fusion which is suppose to be a fix and it gets the same message. Freshly installed Kodi 20…
I guess the link is bad and need a new one. Does anyone know if there is a new link?
I just went back to crewnique, I got Chan to work once but then it said an update was available after the update it wouldn’t work anymore
Its up and working posted in another topic, so this one closed.
