I see the mods closing threads when the discussion appears to be ongoing. Perhaps the mods can add a note of explanation as the last post before closing them?
Threads are closed when they time out or a solution is clicked by the person who started the thread. Mods can close a thread when it has derailed off topic or they deem the topic to be off limits per the guidelines here.
What would you like to know? Topics with solutions get closed. Common questions or conversations that have guides get closed too as they are highly covered. I have always said if anyone needs more info or if something wasnt solved to talk to me i can re open it.
Is there a certin one you feel was closed that needs to be open? Msg me.
Totally agree most of the time it’s been discussed over and over and over again or gets off track they have a good reason when closed and sure you can ask to reopen if needed. See there you go he beat me to it he’s quick
I understand that, but I asked a question in the following thread and it was closed before it could be answered:
And that can be answered by pm. That is also a very common question and its apart of the stremio setup guide as well.
Torrento
Orion
Those will be your top 2. Other stuff is filler. Those are the only 2 addons that pull from rd.
Thanks, yes, I have both of those on Stremio. Orion doesn’t work at all (I’ve worked on it for several weeks and given up), Torrentio works great on RD with Torrent files but not without RD. Hence my question to Miki as to whether there are others.
Then you look for the ones that say just torrentio and NO RD+ It does work without it. Gotta get the links that don’t have RD attached.
Stremio is free.
I add all Movie and TV Series addons. Torrentio alone, without RD, returns many links for each vid. So looking at a popular vid I have over 140 Torrentio links not counting RD. Orion I only use the free one so just get a few sources with that.
