Outside of the wonderful installer put out by Troypoint I have a question regarding the installation of other APKs. Is there a way that I can batch install APKs across 3 different devices? Should I use Google drive or is there a one click installer type program I can use?
Thank you.
@wolfhound Google Drive is a great idea. You could also put the APKs all on a USB drive and just use that to install. Open your file manager and away you go.
I have been using Google Drive with success however, I have always wanted to automate the process. I continue to research online an easy way in which to batch install my “baseline” apks.
If anyone in the community has accomplished this with success I would be interested in learning your process.
Thank you.
