Clone Android TV boxes
I have been using FireCubes and now the Walmart ONN device. As everyone here knows it takes a bit of time to install all the various apps, sign into paid services etc. It takes me a couple days on and off to get most apps setup as I like when I get a new box. I have 3 TVs, 2 are rarely watched but need to be ready to go for guests or grandkids. I have a new ONN box nearly 100% setup the way I want. Is there a way to “clone” this box to my other ONN boxes? That would be a huge time saver.
Thanks!
To be honest, not really. I’m not saying things cant be done but at a higher(much more difficult) level and I really dont think you want to go there. At this point the easiest way is backups…for example if you use tivimate a backup can be replicated on other boxes and programs like stremio can be installed on a pc once and then logged into on other systems including android and firesticks…
There is no good (easy) way to clone. Troy’s Toolbox and saving critical backups like Tivimate on a cloud drive or USB drive is the fastest way to mirror a device, but it unfortunately is still a pretty manual process. It isn’t like you can fit tons of apps on these Onn boxes anyway, so it shouldn’t take long.
