Is there a way to clear your cache on the firestick or on kodi
In kodi, install a maintenance addon like Open Wizard. Caches can be cleared in settings> manage installed apps> apps. Click on any installed app you want, force close, clear cache. Just clear cache only, clearing data will remove any changes you’ve made to an app as well as remove your login credentials.
