Has anyone else noticed that since updating to v2.6 of Cinema hd the real debrid links are no longer yellow! Any ideas or suggestions?
Are the R-D links there? If so, does really matter what color they are?
You can always download the older version.
The yellow links are faster.
As long as the server source link still has [DEB] or something like [Rapidgxxxx - DEB] - anything referencing DEB within the brackets, you’re good, regardless of font color.
I get some RD links on Cinema HD but not near as many that I use to get on that app .
you change your setting in Cinema to real debrid only. For the older tv shows or movies you may have to take that setting off.
Is it worth updating Cinema from 2.5.2 to 2.6? The providers on 2.5.2 are a joke.
2.6 is working well. I skipped 2.52 so I can’t say what’s different other than no debrid colorization.
Are you using it with Real Debrid? Any luck with free provider streams?
Yes, I’m using Real Debrid. Cinema is configured to show only HD and debrid. Haven’t tried any of the provider links since I started using debrid a couplevof years ago.
