CinemaHD clone?
Hello Every one. I am a bit confused. Today 10/19/22 I just thought I would use my FireStick and open CinemaHD, I open it and it was working. It seemed to have new movies/somewhat updated. Or could this be a clone? Any one have any ideas?
I thank you all for taking the time to read my post.
Sig
Someone else has picked it up so may not be gone. Keep checking it.
TJ, I will check it again in a few days.
CinemaHD was my favorite service, I hope someone pick it up.
I have heard many people say their app and sources still work through Cinema. However, I think the future of the apk is very fuzzy. I don’t trust it, so I moved on. There are so many great streaming apps, I’m glad I didn’t settle on just Cinema and expanded my horizons. Cinema is a nice setup and I can see why people always liked it, but I prefer some other apps to it, even when Cinema was rolling a while back.
@AMD237
I’m still using Cinema with no problems at all. It’s like nothing happened to it. What apps are you using now?
Most people went to Film+ and a new one called Tvium. Just be cautious with it and always run a vpn.
If it still works, then by all means use it till the wheels fall off. I would suggest having a backup plan, though, in case you wake up one day and Cinema has completely vanished. At the moment, Syncler snd Stremio are my favorites. Plus I still use the most popular Kodi add ons, and there are many others.
Cinema w/real-debrid is working very well. I use Stremio primarily but some things that Stremio can’t find Cinema does.
AMD, I love CInemaHD because of it’s so simple, but I also have backups like Kodi and it’s add on. It no telling when Cinema will just poof! And be gone. I feel that someone will actually just pick it up and keep it updated. Well that’s what I’m hoping will happen.
I am still using CinemaHD with real-Debrid an still working for me .
I use stremio, filmplus and beetv. I like the feature in beetv that allows you to see acter other moves they are in.
hey rj. Stremio does the same thing and more. Open a movie and on the left scroll down and click on any actor or director name and added info comes up and the movies/series they’re in will display. You can also click on the genre and similar movies will pop up.
Thanks for the info, will check it out.
I still use Cinema Hd but many times the streaming service show’s a completely different movie
CinemaHD with RD gives me tons of high quality 4K and 1080p streams. Stremio with RD also works great with lots of options. Both are very fast for generating streams!
I’ve tried Syncler (Kosmos) and Film+ (both with RD). Both are super slow and only generate a few streams. Was not impressed with either compared to CinemaHD and Stremio.
Caveat: I did not try Syncler+
Syncler+ is our go-to movie app. It’s the best I have used, but Stremio right there as well. Film Plus just a backup for me, works, it is fine, but not great. Sounds like you have plenty of options to fall back on in case Cinema disappears. But for sure, if it is still working as well as it ever did, might as well stay on the Cinema Train…choo chooooo!
Interesting. I’ve compared the number of streams with Bee TV and FilmPlus (both free and RD stream). FilmPlus has a handful fewer streams than Bee but it’s still very good. Cinema, on the other hand returns loads of streams that aren’t the title they are supposed to be!
I checked it out, I still think BeeTV works better. Stremiko requires you to look through multiple lists.
Stremio requires you to look through multiple lists??? What are you talking about. Yes you choose movies or series or what ever library category you want. Having your media devided into things like movies, tv series or genre actually makes it much easier to use. But if you don’t want to look at them, use the search function. Once my library is loaded I never have to look through any sections for my shows. BeeTV you can’t simply install it on any device, log in, and have your entire setup applied without any input from you. But it’s a free world and in the years I’ve been using Stremio it’s never let me down. Orion Real Debrid, Trakt integration it’s got it all. I’ve used BeeTV in the past but imho Stremio is better, hands down.
I’m talking about when you select an actor’s movies not the movies to watch.
