Search for Stremio on Troypoint,com This will take you to a tutorial which shows how to install it and add Real-debrid
Good deal E… yw
Probly a modified or a diffrnt version of Cinema
Or it could b diffrnt devices or os-version of your devices, but its most likely mod-ed
Maybe c if your show is on 1 of the many othr entertnmnt apk’s
BeeTv, & othrs are all very close in look & feel with minimal setup
hth…
Stremio works with add-ons much the same as Kodi. So with Stremio open you go into the menu (hamburger) 3 horizontal lines, top left, and click, scroll down and click Addons, then it opens the addons. Top left is “All”, Top right is “Community” which you can click to change to “official” if you want to view the official addons. “Community” ones are where you will install the 3rd party add-ons that get ypu all your Sources for what you want to watch. Keep i mind that these are 3rd party unsupported apps. For me I only use it for Movies and TV Series, so I enable every addon posdible. once that is fone to uour satisfaction then close Stremio to set them, then re-open it and do a search under “Discover” under the hamburger and search for a TV Series you want to watch by clicking “Series” and then s rolling through them all or selecting “All genres” on the top right then selecting a genre to scroll through the available series or click the magnifying glass and enter a title to search for it. Then once it’s displayed in the results you can click on it choose a season and then an episode and give it a few seconds to load and on the right your sources will be displayed, scroll down, click a source and enjoy. Always use a VPN with Stremio.
https://troypoint.com/?s=Stremio
Please see this mega cinemahd troubleshooting guide.
You can get cinema from apkpure. If you need help with stremio feel free to make a topic on it.
