Cinema HD V2 not working
Hoping for some advice
My Cinema HD V2 app has stopped working, when I open it it shows a blank screen, it lets me select TV or Film and loads, but it shows a message Similar to too many people are using the app and it will not load anything.
In the top right hand corner it shows a box that says something like “movies (something)” which I can click on and it changes to a red logo with a T in it. But that doesn’t change the results
I have tried upgrading and I am using the latest…I have tried uninstalling and reinstalling but the same response… This first happened about a month ago with no change
Apologies for the long message, but hoped to get everything down
If anyone thinks it cannot be fixed, could someone to advise the best/similar movie/TV app for IPTV
Thanks in advance
Hey Char & welcome…
BeeTV is the same exact thing…
Its in unlinked along with many other options…
hth
@Chardgrills
Use the regular version not beta or v2 it’s in unlinked.
My personal recommendation is stremio kodi and syncler.
Is there a comparable option to Cinema that is free?
Hey Teach…
BeeTV is exactly like it, but theres’ a bunch of them in unlinked (this is not a recording)
hth…
Thanks for replying
I cannot get any of the cinema apps or Syncler apps to work…
Tried both old and new cinema, is there a version 3??
Also tried a full factory reset and installed everything again, but still no luck
@Chardgrills
What device you are using? Sounds like you need to make sure to install from unknown sources and if on a nvida to disable any protect. Also check your storage.
Hi
The unknown divice is on, and it’s using a firestick.
I have around 4 gig available for space.
Tried the syncler app again? And it’s just stick on starting download, even leaving for 10mins and the download doesn’t change
I just now checked Cinema HD and Syncler+ both load 100’s of links and every link I tested played fine.
I have the free version: 2.4.0 of Cinema HD and the paid version:1.3.2.1 of Syncler+ both applications have Real Debrid installed.
The only issue I have in Syncler is I can’t seem to enable the “Catalog Dropdown”. I like that feature because it is easier to search around for something you want to watch. The Cinema HD app has this, but the Syncler app, imho, is a better app all around.
If anyone knows how I can get that dropdown catalogue to appear please give me some help. thanks
Btw, I already tried to enable it in setting but no joy.
