Cinema hd throwing out useless links other than movie advertised
I have been using Syncler since Troy recommended it. It has great links for even older films and TV shows. A little tricky to set up initially but well worth it for the quality of the links without any buffering
As mentioned above.
Switch to syncler. Try it with your real debrid account.
Get plus version with real debrid. 6 bucks for real 10 for plus (that’s 4 months) (6 bucks is a month)
And you won’t have these issues. I absolutely enjoy cinema I do, but after the above combo it has solves those issues.
Test both play with it. It should solve those issues.
I have Real-Debrid, so, I need to use Syncler along with Real-Debrid?
I’ll also try using the M4U 720p links - gotta try something :slight_smile:
@antiguanice3
Welcome to our community enjoy your stay.
Make sure you subscription has not run out. You don’t get a warning. Make sure you have time.
Next re authorize real debrid and relink it to real debrid.
If that don’t work, reinstall to latest version re link.
If still issues switch to syncler it is way better. Or switch to kodi plus crew siren and venom with real debrid.
I use to use cinema and cyberflix. I still use real debrid free service. With or without real debrid many links are found but cannot connect to any. I have just switched to fluxoid. Works great.
