When I select a program to stream on Cinema HD, either the wrong episode or a completely different show plays. This happens if I select a Real Debrid stream or a non premium stream.
Hello and welcome to our fourms!
As a new comer to our great community it’s always best to look around the site and go threw our search function. This is a common topic and you will see the same results.
Not trying to be rude trying to help.
This is a known issue with cinemahd. I highly suggest using a alternative apk or kodi for your streaming.
Kodi with seren crew realdebrid
Streamo with realdebrid
Syncler+ with realdebrid
Won’t have a issue with those at all.
Thanks Dracoo! I actually have not been having any issues with my Cinema HD. But my daughter has been having the issues, so I was asking for her since she is not a member of Troypoint. My Cinema HD works pretty much perfectly. I gave up on Kodi along time ago but have not heard of Streamo or Syncler+. I will look into these as I like to have an alternative apk. Thanks for the suggestion. BTW i did use the search function to see if this topic was already posted and didnt see it.
Alot of users have issues with wrong content on cinemahd.
Others have no issues. But it is a common problem.
Try those alternatives. Troypoint has guides for them. I use all three.
