Is there a way to select titles from the search list on the far left whithout
having to type out the entire title?
Sometimes the voice search works on Fire sticks just have to try it. If it turns the bar blue it will work. It should also start populating the list when it finds some matching text.GL
YES.Type the search text and watch the faint background and you will see faint show / movie titles appearing. When you see what you want hit your backwards button and go over and highlight the title field. What you typed for the search should appear with the matchs underneath. Chose the title you want.
