Cinema HD Search Function Not Working
My search function doesn’t return results on my copy of Cinema HD. I uninstalled the program, then reinstalled it to see if that may solve the issue. The search function returned results for the first time it was used and then stopped working again. Be aware that uninstalling and reinstalling the program will result in the loss of all your saved movies & TV shows. Any ideas? Thanks.
Ken
Just noting here, I also have the identical problem for perhaps a week now. Does anyone have any information about this?
Search on Version 2.50 working on Android phone and Version 2.52 working on firestick
After posting on 8/29 about Cinema 2.52 Search function not working, I can now report that Search has started working again. I did not change any settings and do use RD. Quite strange. This problem lasted between 2 to 3 weeks. No change in my connection, router, or speed involved.
