Is anyone else having a problem downloading movies from Cinema HD? When I go to download, the “start” button is greyed out.
use version 2.4.0 works fine get add free one
I’m still using that one too
yes i dont recomend the latest one so many problems the one we use is fine
ps there are a few other apps that work really well like turks/ or onstream /or film plus
How do I download the old version. The new one a sky scanner ad pops up and you can’t get out of it unless you go back to the Home Screen same thing with Bee tv any help would be appreciated
use unlinked code EB2E4A4C earlier version in there add free
