Cinema Hd downloads but titles are not in English
Is the entire app in another language, or just the program descriptions?.
Just the program icons
Other than uninstall and reinstall. The only thing I found was selecting a language in your Closed Caption settings. Check and see if you have [en] enabled. Don’t know if that fixes it or not, but worth a shot.
I just uninstalled Cinema Hd and reinstalled it using the Downloader short code 988552 and in downloaded and installed properly. So, if you have to just reinstall the apk.
CC in english Uninstall and reinstall using both methods still results in foreign language icons.
Where did you download the apk from?
