How do you delete a TV Series from Favorites and History. There is a button to remove movies, but no clear approach on how to remove a TV Series.
You can do this by logging into your trakt account on the website and clear/ delete anything from there.
Option 2: In cinema open the tv series and long click on the series and click as watched every episode, from the on screen option.
Hope that works.
Thank you so much for your help. Option 2 worked perfectly for the history; for favorites, I had to take one additional step, and that was to make sure the “heart” icon in the upper left corner was blank. If the heart was white, it had to be cleared by clicking on it, and follow that with the long click. Again, thanks.
You’re welcome. I forgot to mention checking the white heart. Glad it worked.
