Cinema HD APK Audio Not Working
I updated Cinema HD to its latest up 2.6 and i couldn’t get audio to play on any show or movie…so I try play with and kodi was a option and kodi open and the audio work perfect. If any having this same problem try that…
Make sure HW+ encoding is enabled in your player settings. Sometimes an update may reset the decoder to HW or SW. You can test if the other players all exhibit the same audio issue (VLC, Exo, or MX).
How do i change the setting when i go into setting i dont see any like that and the player i use is what cinema has already . But i keep checking thanks for the info
@hernandezm611 Those settings are not within the cinema app/apk.
They are within mx player or mx player pro.
You can get mx player from playstore or pro version from troypoint toolbox.
Mx player> settings> decoder…see image
MX player settings HW n HW+ also try SW that’s why I use MX pro player hope that helps paddy
