Recently I upgraded to the version V2.6.0. and now a lot of the streams are off center or more often too wide for the screen. Is there a setting adjustment or a fix for this?
Look in you device’s setting to correct that or your TV settings if your stream trough that.
personally, I would uninstall Cinema HD and install Stremio.
