Cinema errors 404
Is there any real fix for the cinema error code: 404. I’ve read some of the other threads and tried them. I’m using real-debrid which used to be awesome and now it’s crap. Help please.
Might give the Sportsfire app or the sister one. Troy just did a great review on it.
I’m using Premiumize with Cinema. Not as fast loading streams but no buffering and plenty of streams to choose from.
I’m using Premiumize for two months now with Cinema and there aren’t many links, and out of those most don’t open! Any idea why my experience is so poor? Any suggestions are appreciated!
Not sure why different apps give different links from these Premium services. I use RD and get different links on Stremio, Cinema, BeeTV and FilmPlus. I thought anything (everything) on the RD servers would be pulled if an app had the authorization(?)
I think it depends on the apps dev and how they have coded their search algorithms.
All these 2nd level APK’s like Cinema, Bee Tv, TheTVapp are never going to be as good as KODI or Stremio. I don’t know why but from reading posts over many years here they just are not. My guess is that the KODI and Stremio Dev’s are just more on top of fixing issues. People like to use these “inferior” apps because they say they are easier to use than KODI or Stremio but in the end IMO there are far more problems with these apps and a lot of them just stop functioning
Can using Real Debrid and Premiumize.me at the same time cause error 404 on Cinema or other apks?
No. Both scrape using their own algorithms.
