I’ve never tried downloading streams from Cinema before, I wondered if it is possible to copy the downloaded file to my computer? I’ve done some reading, but there isn’t a lot of information out there.
Was considering making making a backup DVD for one I already own, as it’s pretty scratched up.
There is loads of info about downloading movies and shows, just not from cinema as people dont typically do it from there. A word of caution, you are risking a tad more than streaming by downloading torrents. We have guides on this. I think you are better off using a app or program that allows you to save movies and tv shows to your library so you can watch anytime.
With torrents you will need a vpn and a anti vrius program.
Thank you, yes I have both of those in use. I always used original source material in the past (to control the quality myself/backup discs I owned, which is legal in my country) and never bothered with downloading. But I’m having trouble finding this title and the disc is scratched, so I thought I’d investigate this route after all these years. LOL
