Hey got a new firestick on live in the uk and the cinema apk not there anymore or says it not allowed any ideas
Have you turned on your apps from unknown sources in the fire stick settings. Since it’s new, that setting is defaulted to off, and must be turned on to allow third party apps
Yes I hav done all that jst does not work but I hav it on all my firesticks except this 1 I bought it say it support it anymore
Hello. Have you cleared cache, force stop, and if all else fails, re install ??
Also, what spice are you DL- ing it from ?? Might be a bad DL or source.
