@JSparta Cinema hasn’t bit the dust , your Firestick has , Replace Firestick!
Which Firestick should I purchase?
I was getting a message from amazon and could still use it but then cinema wouldn’t run even after I re Downloaded it
The ONN 4K Pro one ![]()
Ditch all FireTV devices now. The Onns are the way to go.
If you have the exploit that blocks Amazon updates, no need to replace with ONN. The Cube 3 has better specs/CPU/GPU than ONN Pro or Plus I believe. ONN Plus/Pro better spec than 4K Max Pro Gen 2. If you have any Fire TV devices (Not eligible for the exploit) below 4Kmax gen2, time to get rid of and replace with ONN. If buying new, definitely don’t buy Fire Tv product. Just my 2 cents.
Wonder why that benchmark is missing about 50%of streamers out there.
He doesn’t test as many as Troy and these benchmarks were compiled over several years. Interesting is the fact that the 2015 2nd Gen FireTV Box is STILL pretty much the fastest device out there for single core performance!
Thanks I see the pro and the plus
Any difference between them?
The Pro 4K has 32GB of Storage. I’m not sure how much the Plus has but it’s less. Also the Plus being newer probably has a better processor. I have 2 of the Pro’s love em.
It works i used it yesterday it’s not dead
Yes, Flo from Alice! Not Flo the annoying Progressive insurance peddler ![]()
Hello, debrid service not needed if using my guide here but you definitely need a VPN.
When you say Cinema, is that Cinema HD or something different? My Cinema HD works great on my Firestick 4k Max
Also, I have been waiting on my Firestick to start blocking things before going to the Onn Plus, but have seen no changes since I blocked all updates
I am using cinema hd on all my fire sticks with no issue. I am watching a movie on it now. Also all apps that troypoint suggests I have working on my fire sticks even if they are supposedly blocked. None of my apps have been blocked on my fire sticks.
I’m on the same boat. Was watching Cinema last night on my firestick. I blocked the updating years ago.
2 posts were merged into an existing topic: LocalSend >> Share files to nearby devices. Free, open source, cross-platform
