My version of 2.4 is ad-free and I like it better than 2.6. but my ad-free version of 2.6 I got from APKtime. I forget where I got my ad-free of 2.4
Instructions are the same no matter what version you’re trying to install
I am a fan of OnStream now thanks to my new buddy @Miki. Best feature is when it goes to the next episode all on it’s own.
Just deleted Cinema 2.6 and installed 2.52, because I read here it worked better. Still the same. Have to force stop to get to open again. Also I don’t run all the way to end of show or movie. This is a new problem.
I don’t have a reply. I have a question and I can’t figure out how to use TROYPOINT’s site to ask. I am really not understanding most of the questions asked. I have Cinema HD and IPVanish VPN. When I try to watch a movie I get no sound. Also if anyone can help me with any of this please reply.
Missing the most important piece of info. What device is this on?
The problem with using old versions of these apps is that the sources keep closing down. Pretty soon, you get no streams (unless you’re using Real Debrid, in which case you should be using a different app).
What media viewer are you using? MX Pro or VLC?
I have no problems whatsoever with VLC. In MX Pro there are setttings you have to select in order to get sound.
I use the Fire tv cube new edition. I have a Samsung tv and 2 Vizio tv’s
I use MX PRO.
Try a different audio codec: MX Player supports multiple audio codecs, and sometimes switching to a different one can help resolve audio issues. In MX Player settings, select Audio, and then select “Decoder” and try a different option
I do have to use the Decoder T to get sound and it does cc on the page.
For me, I stated earlier it’s on a firestick 4K.
I’ve uninstalled and reinstalled cinema 2.52 and 2.6. Both have same issue w reopening. Blank screen. Even if I stop before end of show. Also, cannot get subtitles when I click on upper right subtitle option to play and show.
Onstream has become my first number one app to go to.
Cinema still not opening without having to force stop, no matter what I do? Frustrating!
Use downloader and type in this code:28907
Select movies/tv> scroll down to cinema hd and select > then select the ad free version. I have tried it and it works.
Good luck.
Which version? I can try again, but didn’t work on any of the versions?
I’m using something different than troypoint, and am paying 24.99 a month for live tv and all premium channels, including all sports. Can I get all this without paying? Look at my previous posts.
That’s a bit steep. I pay about $80/yr for 2 connections with around 7000 channels which is more than I could ever need.
Thanks. I have unlimited connections, and iptv, etc for phone and iPad. How would I see what you’re using without breaking any rules? I’m also using ipvanish, but looking at Surfshark.
