Cellardoor repository updates fail
Why do I keep getting notifications that my cellardoor updates keep failing? Using a fire stick 4K, up to date running Kodi 19.3. Is anyone else having this issue?
Hi
Cellar door is no longer operating. so if you uninstall it that should stop you getting the messages to update
Hope this helps
Thanks for the update on Cellardoor.
