Ccleaner on firestick
Hi Ya’ll! Wondering if its possible to install Ccleaner on firestick? I downloaded the app but when I try to set my permissions it says sorry cannot install! Any help would be appreciated!!
If it’s a new Max, probably no. Still a bug in permissions.
Don’t know why I said firestick, its the fire cube. But probably not with that either. Thanks.
Should work fine on the Cube.
try sd maid i use it on mine
Ok thanks appreciate it.
